will this work?
neumann
will this work?
Post by neumann »
kevinberry1
Post by kevinberry1 »
I'm guessing you are going to run additional speakers off that amp right?
neumann
Post by neumann »
yeah
kevinberry1
and they would be..... :)
So you are bridging the rear channels to the sub and using the front for components? That should work fine as long as the ohm configuration is the same.
neumann
Post by neumann »
yeah im going to bridge the rear channels for the sub and use the front channels for the components, they are polk audio db5250 components-http://www.polkaudio.com/caraudio/products/db5250/
OnYrMrk
Post by OnYrMrk »
then yes...in a nutshell, it will work
neumann
Post by neumann »
ok good, thanks
