2006 GMC Canyon...installers help?
lotas
Post by lotas »
My brother has like a two month old GMC Canyon, brand new...I have some Coaxs for him (he said he wanted new door speakers) and he also wants a sub.
Now for the sub, there is about 0 options. I'm hoping one of you installers has installed on one of these, or something similar. There is probably 4" of clearance behind the back seats, nothing under the fronts. Any ideas on where a sub could go? Btw the sub I have lying around is an 8" RE RE.
Now as for the door speakers, the GMC stock has a component setup (unless it's a coax down low and just another imaging tweeter up above more on the door panel?). When I put the coaxs in should I keep that stock tweeter there and unplug it? Or should I just leave it be. I'm worried it might mess up whatever imaging might be possible in a truck with coaxs :happy055:
Post by sinister audio »
how about some Mpyre audio 6.5" subs and put those in the rear doors or the rear area. they have 12mm or 13mm of xmax and they run for 120 bucks.
i forget the model number but bill will know it....pioneer makes a 12 with a 4" mounting depth that sounds real nice.....
lotas
Post by lotas »
Thanks for the help guys I will check those out. The only thing im worried about if I was to try to put the sub under the seat is the clearance for excursion. I think it might be too close.
here it is! damn fine subwoofer
http://www.pioneerelectronics.com/pna/p ... 19,00.html
have u used this yet smoker?
lotas
Post by lotas »
Bwcad1 wrote:here it is! damn fine subwoofer
do you sell those bill? how much do they run? I will go measure the depth of the truck real quick and see if it will work.
just measured and it would be damnnn close, fiberglass if anything would work, not enough room for thickness of...well anything but fiberglass.
And I looked at his back door speakers and they don't look like 6.5" look more like 5 1/4" or something...I will look that up in a sec
i have the older models pm me for the price
