Sorting the good bad and ugly
All of the changes so far have been made.
couple of things northstar batteries need to be added to the highly reccomended area i think hifonics should be moved to the good area *with not sayin 05 or later models only!!!* audiopipe wire needs to be moved from good wire to highly reccomended there strand count is higher than even tsunamis competiton stuff. hooker audio needs to be added in the wire section under highly reccomended. autotek amps imo need to be moved to highly reccomended or at least good.
As for the Hifonics issue, that has to be agreed upon by at least 3 or 4 people.
I put Autotek under questionable until some others can agree.
ok well im sure devin will vouge for both. i dont think they should be questionable based on a lack of data or that should be reflected. putting them under questionable makes them look as though they are not very good. maybe a note should be added on the questionable colums stating that not enough data has been givin for the following hence y they are under questionable. autotek amps have a good reputation also there amps were very good back in the day and they still are. just my 2c
05spectraSX
Post by 05spectraSX »
William from NOLA wrote:Here's my initial sorting job of it. I've put my own opinions in as you may see. If there are any changes, put the category and whatnot. I still think a Questionable could be added for each.
Subwoofers
Highly Recommended
Adire Audio
Boston Acoustics
Resonant Engineering
Treo
Eclipse
JL Audio
MMats
Digital Designs (DD)
Rainbow
Arc Audio
DLS
Ascendant Audio
Focal
Dyn Audio
Eclipse
OZ Audio
Image Dynamics
Crystal
Alumapro
Memphis (Mojo series)
Kicker (CompVR series)
Alpine (Type-X series)
Diamond Audio
MB Quart
Highly Recommended:
Inhuman Audio
Elevation Audio
Earthquake
Good
Infinity (Kappa series and up)
Alpine (Type-A or S series)
Pioneer
CD Technologies (CDT)
Rockford Fosgate
Polk Audio
Earthquake
Pheonix Gold
Coustic
MTX Audio (8000's and up)
Xtant
Cerwin Vega
Onyx Audio
Concept
Fusion
Bravox
Questionable
SoundStream
Coustic
Elemental Designs
Avoid
Pioneer (lower models)
Audiobahn
Alpine (Type-E series)
Sony
Pyle
Crunch
Power Acoustik
MTX (6000's and under)
Boss
Planet Audio
Bazooka
HiFonics
Kenwood
Planet Audio
Alphasonik
Jensen
Autotek
Lightning Audio
Alphasonik
Crunch
Volfenhag
you left out Dual subs.
I remembered Autotek being good a long time ago, then went to crap. I haven't really heard much since. So, I'm not sure. I can just take it off the list if that would be better?
05spectraSX wrote:you left out Dual subs.
Fixed.
Post by sinister audio »
i think hifonics and autotek are pretty decent amps. especailly for the money you can hifonics so cheap off ebay and they do kick ass.
i suppose that is fine. durin what years were the autotek amps crap? well i guess to be honest the ss series arnt the best but the mm amps are very very good. i guess its your call. devin did you mean amps or subs? hifonics amps are good and the upper levles like the xx are incredible. the mm autotek amps stomp mad ass in spl comps
ya i was thinking of subs when i wrote it.
