Increased HU voltage
a line driver gives you a stronger signal with less distortion letting you put more power to the sub without risking blowing it up. and us spl guys gain quite a bit by turning the gain up gentlemen i know thats not what its for but i have metered about 2 db higher with my gains set higher than usally.
Because the gain isn't voltage, its sensitivity. So if you raise the input voltage you would turn the gain down, so you don't overdrive the input stage.
Now if your amp list voltages on the gain, you would be increasing the voltage acording to the knob. However you would be doing this by turning the knob down, not up.
Bill I can agree to a point that you might see a small gain, but not one of 2 DBs, unless your clipping the amp. Especially in a set up like yours. Say your running 3000 watts, in order to gain 3 DBs you would have to double your wattage to 6000. So if you got a 2DB gain from a line driver, then it would have given you an extra 2000 watts.
http://www.lenardaudio.com/education/03_db.html
