Can i run my component system with a tweeter missing
Post by Mithrandir »
and not damage the woofer. See i took a tweeter out because it was bad. Can I still run it with the tweeterless woofer hooked up or should I disconnect that channel all together?
stephensmia
Post by stephensmia »
you should be good
DEFENSOR FORTIS
done it before......
MrSo0h0o
Post by MrSo0h0o »
i dont think theres anything wrong. all it will do is leave you with no highs on that side. wont damage anything
ok cool, plus this will allow me to be sure it was the tweeter not the woofer.
Depends on the type of crossover. If it's a 2nd order or higher, which most tweeter highpasses are, DO NOT run it without a load. 2nd order crossovers have either an inductor or a capacitor in parallel (depending on if it's a HPF or LPF), and at the crossover frequency or a multiple of the crossover frequency, this inductor will shunt it and create what is very close to a dead short to the amplifier, the only resistance being the speaker wire and the inductor or capacitor. Not something that you want to occur.
Post by sinister audio »
ya if its a cheap comp set then i wouldnt worry about but i know the bravox kevlars have a 4th order linkwitz riley crossover and they get mad really mad when you dont have everything hooked up right. most cheap comp sets dont have very many parts to them and mainly caps. but a 4th order one is alot better its also harder to design/make and more expensive. (im crossover smart now i just read a book on it)
OnYrMrk
Post by OnYrMrk »
I agree with Devin...I know I am smart, I just stayed at a Holiday Inn Express last night.
well this thread is resolved, i put the tweeter back in, sorry for bein such a pain in the ass guys
