Fixing a damaged channel on an amp
How hard would it be and would I need expensive tools? Id like to fix my US acoustics 150rms x 2 amp but dont have money to spend on tools or id just buy a new amp.
- Chris from Washington
Unless you know what you're doing and have a basic understanding of electronics, you might not want to do this.
Plus the outputs can get expensive too depending on which ones are used. Without being able to test components, you can replace all the outputs, just to find out that a diode somewhere else in the circuit was the bad part, that cause the outputs to go. Turn it on, and poof. all those new parts you just put in are now toast.
