"And what is this going in again? My single cab s-10 I had the four 8's behind my seat. Can't you just move the seat a little bit forward?"
S-10s have more room behind the seat. Remember this is an 86 Ranger, they didn't up the size of the regular cab until the 98 year. Moving the seat really far forward is a no-no, because
1: I'm tall
2: I don't want to screw up the soundstage of the truck for subbass. I'd rather lose one octave than screw up the other 9 to get it.
I've already bought the sub, and I'm going to do everything I can to get it in here comfortably. It'll go somewhere.
Right now I'm figuring up a kickass soundstage :) I think it'll be cool and something different if I can get a 5.25 or 7" mid playing 30hz than a sub, just for the eye opening factor
. I could still have the sub to compliment the stage when I wanted (or needed) it. Just the mag cone Excel with the older motor can go to 30hz flat in a car door, no telling what the newer ones can do saying they have a lot more linear excursion. So yeah, it's doable, no question there. I would rather have the ported box to limit excursion down low, if it were too much I could EQ it down and lessen strain on the driver down low. Using the sub, I'd still get sick midbass output from ported front mids, along with them being notably cleaner at higher volumes.
"how big of a ported enclosure can you get for the Seas? i know my bravox will play into the 40hz area open room with a .5 cube box and in the car with a 1 cube box i could play into the 30hz area with only a 5 1/4. so if you have the room you should be able to do it."
I've run over a few options. With the W18E001 (7") mag cone Excels, I can do a .68 cu ft net enclosure tuned to 36hz, the W18EX001 (stronger motor, lower Qts) can do a .26 net tuned to 50hz, both being QB3 alignments. Out of the 5" mids, the W15CH can do a .6 cu ft net tuned to 36hz, and the W15CY can do .24 cu ft net tuned to 43hz, both of those also being QB3. The W15CH is the best midrange performer and has the better motor design out of the mag coned excels. I haven't plotted the Nextel paper coned drivers, but I've seen Klippel analysis and they have the most linear motors (they're the newest design). They'd also be easier to work with as far as the crossover design, as it wouldn't require a notch filter. Bad part is Fs is higher, tuning low isn't a big option with either of them. Anyway, they make a lot of drivers and I'd have a lot of options. Most of their home setups can go into the 30s in room, not counting what they'll do in a car.
Maybe I should become a car manufacturer, and for the factory system I could design the doors to be one huge TL enclosure
