Hertz?
stephensmia
Alright, I'm gonna have to read this thread over a couple times more to catch all of that. Thanks for the quick responses all!
Another question. Is there anyway I can figure out what my subs are best tuned to other then by ear? Any formulas or anything I can punch info into? Here's what my Subs/Amps/Boxes are.
Amp: Kicker KX350.2
Subwoofers(2): Resonant Engineering RE12s
Sealed Boxes(2): 15"x15"x15" Boxes 1.424sq.ft - 0.14 Displacement of woofers = 1.284 sq.ft
The stat sheet for the Subs
http://www.reaudio.com/html/images/re_ts.gif
Amp: Kicker KX350.2
Typical myths about ported boxes:
1: Porting a speaker increases efficiency by allowing the back-wave generated by the driver to reinforce the front-wave.
2: Ported speakers have higher distortion than sealed enclosure speakers.
3: Ported speakers are more dynamic than sealed enclosure speakers.
4: The output of the port and woofer are out of phase with one another.
5: Ported speakers aren’t accurate as sealed enclosure speakers because ports (and passive radiators) are resonant device
Thats called cancelation. With the subs firing forward some of the freq are bouncing of the back wall and then mixing with the sound waves comming of the front of the sub. The best way to stop it is to seal of the front of the box (subs) from the rest of the trunk.Mithrandir wrote:not to hijack a thread but can having subs faced towards you instead of at the trunk totally eliminate a frequency because certain bass notes are like they arent even there, unless I open my trunk. My subs face the front of my car
You could also try some diffrent box positions and see what helps.
http://www.caraudiocentral.net/forums/s ... .php?t=233
stephensmia
