Accord kickpanels.
Accord kickpanels.
I am looking for some pics or ideas for some kickpanels in a 2005 accord. My bigest problem right now is that the factory fuse box (2003 up) is located behind the drivers side kickpanel. So I have to move the speakers way back, and cut out the foot rest, or I have to relocate the fuse panel. So I was wondering if any one has delt with the new accords, or know someone that has. Pictures would be a huge plus! I am one of those people that if I can see it, I can build it.
Oh yeah I looked thru cardomain.com, and saw many things that made me scratch my head and wonder , but not a single kickpanel
I would really like to do a panel like this (its in a 2002 accord) but it won't work in a 2005.
P.S. any kickpanel info would be apreciated (tech stuff, and so one)
that looks nice but i wonder how the sound is affected since plex isnt acoustically transparent?
A person who gets it like that usually doesn't care.
smoker wrote:that looks nice but i wonder how the sound is affected since plex isnt acoustically transparent?
I couldn't tell you, it does look nice, but I wasn't planing it in mine. (The rest of the install can be found here. Scroll down and its the 3rd and 4th row.)
http://www.cartoystulsa.com/gallery.php
I would like to do a peice of grill cloth over mine in some sort of removable panel. That way it lookes nice, protects the speakers, and doesn't hurt the sound to much.
Get some pics of the area.
Maybe the door panel is a better idea?
ive found that if you can get a 6.5 in the door to fill out the midbass it is sometimes easier and in my opinion sounds better to put a 4 and a tweet in the kicks......
Ryan from Ohio wrote:Maybe the door panel is a better idea?
Yeah I have it in the door now, and it sounds good, but the sound stage could be set up better.
Right now it is centered to the driver, but as things move right and left from center they get jammed together. An example is the IASCA setup disk (the track with the seven drum beats) the 4th is centered like it is suppost to be, but the spacing from center to the right and left is off.
smoker wrote:ive found that if you can get a 6.5 in the door to fill out the midbass it is sometimes easier and in my opinion sounds better to put a 4 and a tweet in the kicks......
Yeah I probably should have done a 3 way set instead of 2 ways, but I didn't know about the fuse block till after I picked up the car (everything all ready installed). I had always planed on doing a set of kickpanels myself, once I got the car to germany, and I figured the 2 ways would work just fine.
Pics 1 and 2 are the drivers side. You can see the panel for the fuse block, and the foot rest I was thinking about removing.
Pics 3 and 4 are the passanger side.
Copy of PICT0203.JPG (52.7 KiB) Viewed 526 times
Copy of PICT0204.JPG (50.35 KiB) Viewed 526 times
Copy of PICT0214.JPG (59.17 KiB) Viewed 526 times
Copy of PICT0202.JPG (44.89 KiB) Viewed 526 times
sometimes just playing with tweeter placement will get you there too.....
Yeah I tried that to, but I only have a few places to choose from. If go to high the tweets sound like crap, and I can't really fire them across on the kicks because of the fuse block. (again leading me back to some sort of kick panel)
I posted some pics on my last post too.
geeeezzzzz.........that drivers side sucks.....you have the hood release to deal with too....ever think of going in the floorboards with them? i did that once in a cavalier with good results....
