what is wrong with my remote start!? help installers
Alright guys I have a Compustar alarm, its not the nicest but the next level down (cant think of the model #) anyways, its installed on my manual Honda Accord, and for the first 3months or so it worked great. Then one day I tried remote starting it and the engine will jsut fire but wont turnover. I took it into them and they replaced somtehing like the Honda mobilizer or immobolizer or something....
anyways it was fine for another month and then it went out again, so I took it in again, and they said all they had to do was reprogram it. Well this was about a week ago and its already out again. If I try to start it the engine just clicks and fires and tries to start but wont turnover and start up. Another thing its doing is my door locks are just randomly unlocking. So if I arm my car, the alarm will just go off randomly because the locks are unlocking and its armed so its thinking someone is breaking in trying to unlock it or something....so i cant even arm my car because it will just constantly go off.
what the hell is going on?
I would take it back again and explain to them you are unhappy with all the problems its been having.
Chances are its installer error. Compustars are backed with a lifetime warranty... SO if its bad they gotta fix/replace it. Doesnt cost them anything...
for that car you need a transponder type immobilizer...it sounds to me like its not picking up the correct frequency......did you have to supply them with an extra key for this install?
do you know what model # the immobilizer is that they used?
also if they had installed it correctly #1. the locks would work correctly and #2. if the remote start is unlocking the doors they should have used the correct wiring to the arm/disarm functions so that it wouldnt trigger the alarm
i dont know what else to tell you online but it may very well be a faulty unit and they may very well know what they are doing...
damn smoker. yeah immobilizer that was it. I did have to supply them with an extra key...everytime I'd have it fixed they'd say "do you have another key to the car? we need another key" so I'd have to give them the 2nd key. I don't know what the model # is, no.smoker wrote:for that car you need a transponder type immobilizer...it sounds to me like its not picking up the correct frequency......did you have to supply them with an extra key for this install?
and the stupid door locks thing really pisses me off...i dont know what the hell is causing that. its like a malfunction, my doors just randomly unlock themselves. maybe a ghost is in there hitting the power unlock button
i hope your getting all these keys back? those type of immobilizers have a small box that wires into the remote start and you install an extra key inside of it...usually for my customers peace of mind i install the head only and give them back the key part....anyway this thing wires to power and a few other things iginition etc..but one of the wires is a wire that grounds the immobilizer during remote start...this energizes a coil inside that surrounds the head of the key and transmits that frequency through an antenna that ends in a loop that is supposed to be mounted around the key cylinder in the steering column or wherever you stick the ignition key in (dash or console, wherever the ignition key goes) this tricks the factory system into thinking that you have a key in the cylinder....sounds to me like they are haveing trouble getting this antenna to stay put...they can be finicky and some of them even specify which way to run the wire that goes back to the immobilizer box.....
i still dont have a good answer for the lock/unlock unless maybe your car locks and unlocks when you put the key in the igintion? then it could be that they have taken a shortcut and wired this thing to constantly be on, this would also account for tthe remote start not working because most pats systems will not allow you to unsuccessfully try to start the car more than 2 or 3 times before not letting it start for a few minutes...
ok im having a vision......the imobilizer gets constant power and recieves its negative input from the brain during remote start....if they have tried to shortcut this by merely grounding this wire then the immobilizer will have constant power..it also outputs to the ignition wires but not the starter wires so it could make the system think you are putting the key in and turning it without actually making the car crank because the system brain is not recieving the remote signal if your car locks the doors when you put the key in and turn it and then unlocks when you take the key out i would suspect this MAY be whats happening.....which would also explain why it wont remote start because it is cycling the ignition without cranking it and then you go in the car with a different key and it starts......if it doesnt always start with the key then they need to use the keysence and a relay to make it work because some systems dont like to see 2 keys at once.....
i hope that made sense
Ranger SVO
- Member
I think you said it all smoker. Most remote start problems are install related. There are some installers who try to short cut the immobilizer part of the install and that WILL cause problems.
lotas, Take it back and complain really loud. Everyone makes a mistake, but if it keeps happening there is a problem
I advise calling COmpustar and complaining.
To be a dealer of Compustar you have to be a confident installer, which these guys dont sound like.
Maybe Compustar can have some pull in getting them to fix it right or to take it to another COmpustar dealer and get it fixed properly.
