Sunroof and vibration problems
Post by Mithrandir »
Well basically my sunroof is broke. I think its leaking air, no water or snow gets in which is good. My windows are often fogged up if I go in a store and come back out. 2 stupid girls were messing with it and broke the crank that opens and closes the roof (the crank kind suck, id rather have one that like hinges open).
Can you replace the crank with a hinge(sp) type? or do you have to replace the window too?
Also a lot of stuff in my car vibrates with my bass. I think most is plastic because it sounds like vibrating plastic. The plastic on my sunroof handle crank vibrates bad and I think some trim by the back seat and other stuff. What can I use to quiet this down?
Thanks guys
as far as the sunroof goes you will need to replace the entire assembly....usually it is best to go with a slightly larger sunroof....check out c.r lawrence for quality sunroofs.....
as far as the vibrations go look into some sound deading materials....making them heavier will help with the vibrations...
im just lookin for somthing under 300 bucks probably.
