Rear fill or no rear fill?
I think on the whole you have the makings of a nice sq machine. Kicker is the only thing holding you back. the diamond hex are fantastic speakers, Headunit is amazing (I have one too), Amp is more than adequate. Kicker pre-mades were designed to go loud, but not exactly cleanly. I would even venture to think if you took out that sub, had a professional design a box that is true to specs, your output would probably be closer to the quality you desire. It is just that the premade boxes are designed to get loud, not to really be clean. Hope this helps
eventually you will have to do it right, so now is as good a time as any.
I was more talking about a mid/high set up in the front with a single sub in the back. You can run more speakers, like OnYrMrk has his set up, but you can't be fully active thru the headunit like mine is. Both ways are really nice, but once you start adding speakers it does get more complicated.
Hay OnYrMrk, how are you planning on running your setup?
The second set of tweeters is a good idea if you need it. I would wait and see how it sounds, and then add them if you feel the sound stage is to low.
One more thing. I don't know how much experiance you have with that deck, so I thought this might help.
http://www.caraudiocentral.net/forums/s ... php?t=1416
I still need to go thru and add some more stuff, like using the pink noise sweep to set the x over, and x over slopes, but I haven't had time. So if you have any questions feel free to ask.
Jeremy,
An Audison amp to each side of the K3P's, and the sub amp/sub
using the Focal crossovers due to getting over budget
