which amperage can i use?
jimscreechy
there is a 8 amp glass fuse for the "accessory" line in my car (im installing a new cd receiver)- the fuse is blown, i cant find any 8 amp fuses, can i use a 10 amp fuse instaed?
jimscreechy
Re: correct amperage
its coming from the car.
jimscreechy
it is a 1993 camry lumiere. basically i am not getting ne constant power to the unit. i can insert and eject a cd, press "display" to see the time come on for like 5 seconds, but it is not playing, after looking around, i found that a fuse was blown, its a fuse attached to the "accessory" line (red), its encapsulated in a plastic tube which u snap open. HU? are u asking me what brand is the cd receiver? its a JVC...i rellay cant remeber the model. I have installed a radio before..i belive its a poer issue now that im facing though..and the only thing that seems to be going wrong is that the fuse is blown..ive checked all th eoter fuses in the car..in the hoood and also in the dashboard..thx
try radio shack?
if its the correct fuse and blows again the unit is faulty or wired incorrectly.
no dont go higher thats a nono you should never go higher.
go lower if you have to and cant find a perfect replacement...if it blows then you are gonna need to find the exact fuse, and if you cant do that, then i dunno, but i really wouldnt say go higher. not saying you cant...its just not the right thing to do
oh and Bill is right...if you are having problems with constant power then you are not dealing with the ACC, you're dealing with the battery wire. Does it do all this when the car is on? How about when using just the battery and the car is off?
