1995 Pontiac Firebird firewall?
Hey installers, you guys ever install on one of these? my buddy has one and im putting an re10" in for him, just wondering if theres a specific location you know of where to get through the firewall?
I try to run the power wire right along the factory wiring. Newer cars are harder though as not only do they use tight fitting gromets, but they tape them also!
ouch...
I would try to go that route first. With just that single 10" Im guessing its a small amp and power wire... If its just a 150WRMS or so amp 10 ga will be fine.
ouch...
Chris from MI
You can usually find a grommet to go through. Luckily the rustang had a completly unused one in the fire wall that was even big enough to fit my 1/0 through. Be careful if you do drill thru cause hitting wires can really suck. Also if you use the same one as the throttle cable, be sure that you don't put any resistance on the cable or pinch it. That would suck to have the peddle hanging up.
I have a 95 firebird and I just ran the wire around the firewall because i couldnt find any place to fit 1/0 and didnt want to drill anything. I went down the passenger side door and up into the floor on the passenger side where there was already a grommet(dont think it was a factory grommet but not sure).
