Hey guys,
I have this amp,
LT980/2 Power Acoustik 2 Channel LT Series Car Amplifier (980 Watts)
http://shop.store.yahoo.com/csexpo/ltpowac2chan1.html
and one place that iwas going to have install, said they wanted to use a bigger fuse but none of the other places said they would. Now i was wondering, im going to have a 4 gauge wire, and would a AGU Fuse Holder with 60A AGU Fuse be okay to use? or would i need bigger?
Fuse to small?
- Chris from Washington
you mean for the amp or for the powerline?Bwcad1 wrote:yea use a 60 there is no big problem running a smaller fuse. you get problems when you run a bigger fuse
i run an 80amp fuse by the battery and then 2 more 80 amp fuses at my distrobution block... is this a problem? Why would having a biggier fuse be a problem?!
