Rear speaker removal on a 95 sunfire
Ok my rear speakers arent hooked up, why I dont know. They are 6x9s. The wires wont reach the speakers. The speakers are up inside the rear deck. Not hanging by brackets like in the cutlass i drove. How do I take em out? Does the top of the deck come off? I plan on buying 2 kicker 6 1/2 midbass speakers (125 rms) to put in there so I wanna make sure they will fit and such. Plus i want my damn rear speakers working for now.
You will want to take out the rear seat.
GM Cars... Usually two Torx type screws or two pull tabs on the bench seat part. Like where it meats the floor carpet. Take them two off pull the bench seat out. Then there are like 203 nuts holding the backrest on. Take off and lift UP!.
Next is the plastic that touches the rear deck. Remove ONE side.
THe deck should come off with a bit of fight, fold GENTLY. Bend it in a few spots but no TIGHT bends...
Make sure you have everything you need and only do this once as its a pain in the arse!
