Box Maker
Size 12"
Woofer Cone Material Interlaced Carbon Fiber Reinforced IMPP Cone Woofer
Surround Wide-Roll 3-Layer KEVLAR® brand Fiber Woven Radial with Honeycomb Cloth
Overhung Surround Design
Voice Coil High Inductance, 4-Layer, Long Voice Coil
Voice Coil Wire Y
Voice Coil Bobbin 7-Slit Glass Imide Voice Coil Bobbin
Damper (Spider) Y
Top Plate Thick 1.2" (30mm)
Projected Pole Yoke with Vented Pole
Aero-Dynamic Magnetic Gap Design
Magnet Construction Massive Triple Stacked (320 oz.)
Basket Design Aluminum Die-Cast Rigid Chassis
Gasket (None)
Wire Terminals 8-Gauge Wire Terminal
Specifications
Watts MAX. Music Power 5000W
Watts Nominal Power Handling 2000W
Frequency Response 18Hz ~ 2kHz
Sensitivity 88dB
Ohm Rating DVC (2ohm or 8ohm)
Recommended Enclosure 1.5 Cubic Feet
Voice Coil Wire Y
Damper (Spider) Y
Gasket (None)
Specifications
Sensitivity 88dB
