Sorry man
If you can check the Amps specs I would be grateful
It's a 4 channel Amp and I will be using bridging 2 channels to get 162WRMS @4Ohms
The other 2 will be used for a component set
Will it be enough?
Cheers
if you have the dual 4ohm sub itll be about perfect, remember just dont clip the amp and youll be alright it wont even be noticeable if you had 60 watts difference if you have the single 4ohm sub.
Bwcad1 wrote:its dual 4ohm or single 4ohm isnt it? it can do both cant it if i read the pdf correctly?
You mean the Sup or the Amp? (the pdf is for the Amp)
Yep the Sub is both dual and single 4Ohm
And the Amp is bridgeable and can run 4/3/2 speakers on 4Ohms.
How does the dual 4Ohms Sub work? Does that mean a dual voice coil? Can it be connected to 2 amps, run as a 2Ohm or maybe 8Ohms???
Cheers
Cheers
The only way to run a dual 4 ohm v.c. sub to 2 ohms or 8 ohms is the way you wire the v.c.'s together. Parallel configuration will give you 2 ohms and series gives you 8 ohms.
I would not recommend running 2 separate amps to a single sub. If the adjustments are off on the amp a little, it could potentially harm the sub. Just use one amp for that sub.
