elevation101 wrote:The guys from Myth Busters proved that the using the a/c on todays cars actually got better mpg then with the windows rolled down because of the drag.
! I was just going to add that.. i too watched that one..
they did an extensive test you could say, on all sorts of differnt speeds, and windows up / down..
The conclusion was the ac affected gas mileage so lil that you wouldn't notice it.. compared to the windows being down, increasing drag.. and so on..
Hell i could care less if it reduced my mpg by 5 i'd still use it :) lol
I saw that one. The difference is still considerable.
if you're curious, the A/C compressor draws about 35A of current, as well.. and the added drag on the alternator also decreases mileage somewhat, just as a technical aspect.
With small 4cyl cars a lot of times you'll really feel the drag on the engine with the AC turned on.. going up hills or accelerating almost comes to a stand still if you have an underpowered car to begin with and then add AC. Even more so with sluggish automatic transmission four bangers.
I use the AC in the Jeep a lot in the summer, but that's got a 4.7L V8 and dual zone climate control, so the AC isn't blasting full force the full time it's on, and gas mileage isn't reduced that significantly truth be told.
KikiTheCat wrote:if you're curious, the A/C compressor draws about 35A of current, as well.. and the added drag on the alternator also decreases mileage somewhat, just as a technical aspect.
thats exactly how it is on my honda. (4cyl stick)...I lose so much power if I turn the A/C on, the gas is so much different. It almost feels like a whole different clutch spot, you really have to baby the gas/clutch to have a smooth take-off, and once you get going you have 0 power :-/
not that my 150hp honda has power anyways, but, you know what i mean
yup. you lose the responsiveness the car normally has, and suddenly it feels like you're towing a small house behind the car.
I've had 4cyl cars like that with AC on.
It makes it a lot worse when you're driving in mountains and such.. also heats the engine up a lot faster which isn't very good on the motor of the car for longevity.
I feel more comfortable with the windows down as well..The main proiblem i have with using my ac is that sometimes i'd rather get out and walk than try to accellerate, and it doesn't always blow as cold as i like. Plus i can hear alot more rattles from my trunk. going to deaden it this weekend.
