In need of tweeters
Sometimes its the glue they use to assemble them.
But usually that only occurs when the speakers are newer.
Your probably clipping the signal from the head unit and in turn its building up heat quickly.
If they are not damaged it would be best to keep the volume to no more than 3/4 way or/and add a decent amp.
- NorthQuad
Yeah these Kicker 5x7's are new, it mabey the glue because it doesn't smell like they are frying but it is a strong smell. I don't really want to pull them out because they weren't cheap and I would have to get someone else to do it because the door panel would never be the same if I tried to pull it off. I really just want to add more speakers because the one pair alone just won't get the level of sound and quality I want.
You would be amazed at the difference in sound if they were amped...
audiocr381ve
