didn't realize the previous post wasn't open, so i will post it here as well.
here's a good thread on the subject (the bl curve on pg 5 is pretty unprecedented)
http://www.soundsolutionsaudio.com/...?showtopic=2748
these are Mike's tentative revised specs:
"Will be released in both 12" and 15" sizes
Will be built upon the TC3HP motor
Will offer up to 38.15 mm one way Xmax - True 3" peak to peak excursion!
RMS rating of 800 watts - Peak power handling of 2 kW.
Will use a 2ohm single linear voice coil
Will feature a powdercoated black/grey chrome basket
Will use 4 x (7.5" by 0.75") magnets
Will carry dual 9.8" spiders
Will sport super sexi black annodized aluminum cones
Some preliminary spec's for the 12" model:
Qts: 0.489
Fs: 22 Hz
Vas: 57 L
Sd: 501 cm^2
Some preliminary spec's for the 15" model:
Qts: 0.535
Fs: 20 Hz
Vas: 164.5 L
Sd: 851 cm^2"
