Ground wire with 2 amps question
BlindSide1801
Post by BlindSide1801 »
Ok, just a quick question. Would it be better to run sperate ground wires from 2 amps or get a Distribute block and run one ground wire?
Thx.
Distributor block or two seperate grounds to the same bolt.
BlindSide1801
distributor block to same bolt or seperate grounds to different bolts... which is better, im getting engine noise threw my speakers and mine are sperate grounds to different bolts, im wanting to konw if that could be the cause.
I don't see that it would hurt to have sepate grounds, as long as both were properly done. Personally, I use a single bolt, and a distro bock, in my installs and have never had any problems.
LIL CHRIS
Post by LIL CHRIS »
Yeah i wanted to know too if you could run one power wire to one amp and another power wire to another amp and the grounds the same way i know you coud use the same remote wire but i dint know about the other stuff. im new here and it's my very first post!
Yes you can run two power wires, but its alot easer to run 4 guage or so back, and come off of it with a disto block and two 8 guage wires. Same way with the ground wire.
