really confused about DVC subs and how to wire them
chazcheetah22
If they are 100watts to each coil do you need 2 channels on your amp to wire them to? Or can power both coils correctly with a mono amp.. Everything I read is very unclear just says you have all these options with said system and that's about it.. I'm hoping someone on here can talk to me like a normal person not someone who has spent years studying audio like everything I find online. Thanks guys
Re: really confused about DVC subs and how to wire them
Does this help?chazcheetah22 wrote:If they are 100watts to each coil do you need 2 channels on your amp to wire them to? Or can power both coils correctly with a mono amp.. Everything I read is very unclear just says you have all these options with said system and that's about it.. I'm hoping someone on here can talk to me like a normal person not someone who has spent years studying audio like everything I find online. Thanks guys
Subwoofer Wiring Diagrams
Or maybe this one.Good luck:
Subwoofer Wiring Diagrams | Sonic Electronix
No, you do not NEED two channels. Yes, you can wire both coils correctly to a mono amp.chazcheetah22 wrote:If they are 100watts to each coil do you need 2 channels on your amp to wire them to? Or can power both coils correctly with a mono amp.. Everything I read is very unclear just says you have all these options with said system and that's about it.. I'm hoping someone on here can talk to me like a normal person not someone who has spent years studying audio like everything I find online. Thanks guys
An exception would be dual 2Ω voice coils wired in parallel to a mono amp with a minimum speaker impedance rating of 2Ω, let's say.
