Do I need a bigger battery or alternator?
Dr. Bogger
Hi All,
I am in the process of installing a new sound system in my 2010 Honda Civic LX.
Here is what the system components are:
1 x JVC KD-HDR70 Head Unit
4 x Alpine Type R - 6.5" Coax. Speakers (SPR-60)
2 x Alpine Type R - DVC 4 Ohm - 10" Subs (SWR-1043D) - Wired to 1 Ohm
1 x Alpine Amp - 50W RMS x 4 CH @ 4 Ohm (MRP-F300) - For the SPR-60
1 x Hifonics Brutus Amp - 1200 Watts RMS @ 1 Ohm (BRZ1200.1D) - For the subs
1 x 2.0 Farad Capacitor - db Link LCAP2KF
1 x KnuKonceptz KOL-AK4-4 Amp Installation Kit - 4 Gauge
w/ Distro. Block + 150 Amp Fuse + Accessories for Dual Amp
So my questions are:
1. Will I need to put a bigger battery in my car?
2. Will I need a bigger alternator?
AND
3. What will the consequences be if I don't upgrade them?
Thanks in Advanced.
AND
Thanks in Advanced.
Not that Bill needs me to approve, but he is dead on.
Forget the cap, upgrade the battery to one designed for car audio, and run a bigger power and ground.
I've seen a couple debates recently on upgrading the big three, and if it really helps. But I still think it can be beneficial.
As for the Alt' that's a wait and see. The Civic alt' isn't very big. I believe the 2010 LX is only an 80 amp. But its pointless spending money on a new one if you don't need it.
So get everything installed, and then keep an eye on your head lights. If you notice them dimming a lot, then upgrade the alt'. If you don't have a problem with them dimming, then the one you have if fine for the current system, and the volume you like to listen at.
Dr. Bogger
Dr. Bogger
I think this will fit in my 2010 Honda Civic LX, but can somebody here verify if i'm correct?
http://www.sonicelectronix.com/item_179 ... -BT60.html
Dr. Bogger
Dr. Bogger
