buying stuff from knueKonceptz first time - couple questions - maxi fuse size/RCA's
casemods
Post by casemods »
Ok first off, I am replacing the RCA's I have right now.
I am using 20ft pheonix gold rca's for the rear, which will go to the sub.
Then I need 2 sets of 6 feet for the 4 channel amp.
I was thinking about buying these 2.
The cheapest one on the site only has 16 foot and I need shorter.
Knukonceptz product detail for KLARITY RCA CABLE 2 CHANNEL RCA KABLE 2 METER
Second, the distribution block I have has two 40 amp maxi fuses. Should I replace those with 20 amp?
I have 4awg with a fuse 1 foot from the battery, then the distribution block goes into 1 8awg, and finally the one 8awg goes into about 10 or 12awg with a 10amp in line for the 4 channel
As far as I know, the RF p500-2 has no built in fuse for some reason. Perhaps they use protection that doesn't require them? All I know is both RF amps I have do NOT have fuses and I am not ballsy enough to not have them.
ALSO: what size fuse should I have at the battery? It's the AGU type fuse. Not sure what size it is right now.
I would like to stay as safe as possible
