wiring a aftermarket for a 98 lexus es 300
tah
Post by tah »
can anyone tell me what coler the stock wires are which wires they are, ignition, power, ground, ect?
Constant 12V+ White Ignition Switch Harness
Starter Red Ignition Switch Harness
Ignition Black/Red Ignition Switch Harness
Ignition 2 Black/Yellow Ignition Switch Harness
Accessory Blue/Red Tests as Ignition
Tach Black Or White/Red 4 Cylinder At Coil Pack.
Brake Switch Green/White Brake Switch
Trunk Release Red (-) Driver's Kick Panel
Trunk Pin Green/White (-) Driver's Kick or Factory Alarm Module*
Parking Lights Green/Black (+) Driver's Kick Panel
Hood Pin Black (-) Switch or Factory Alarm behind Ash Tray
Door Trigger Red/White (-) Top right of Fuse Panel
Door Lock Blue/White (-) Driver's Kick Panel
Door Unlock Red/Green (-) 2 Pulse to Unlock and Disarm Alarm
Horn Wire White Connector bottom Green/Black (-)
Windows Up LF=Green, RF=Green/White, LR=Green/Yellow, RR=Green/Black
Windows Down LF=Red, RF=Red/Blue, LR=Red/Yellow, RR=Red/Black
tah
Post by tah »
what about the speakers and remote wire and what is ignition 2 for
tah
Post by tah »
im confused i need to know what coler the ignition ground power speakers and remote wire are. the ones that come stock because i cant seem to find any harnesses for the model lexus i have
ok what are you trying to do first of all.
Ground black but you should ground to some metal on the body or frame There is no schematic for the speaker colors and the car doesn't have a remote wire that's for turning amps on.
I highly recommend you take whatever your doing to a professional before something catches on fire.
tah
Post by tah »
put an aftermarket radio in my car but without using a wire harness clip thing
This website has all the necessary wiring adapters and dash kit information take the part numbers and search them.
http://www.metraonline.com/fit.aspx
Do not cut into your factory wiring. Take it to a pro and let them do it the right way.
tah
Post by tah »
im trying to figure out which wires to connect the aftermarket radio to in the car
tah
Post by tah »
im trying to do this just for the sake of being able to do it myself i want to learn. this is what i want to do for a living
