infinity 5350a
infinity 5350a
ive gottan a question for everyone=I have 2 5350a infinity 5 channel amp and i was wondering if it was ok to run 1 sub off of each amp???????????
infinity 5350a
colemanyoungerinalaska
Yes you can run a sub off of each amp. But.... I think your going about it the wrong way.
The amp only has one sub channel. Its rated at 150 watts at 4 ohms.
Thats the only channel you can run your sub off of. The other 4 only put out 50 watts rms, so hooking anything other than components or a coaxial would be a waste.
Why not sell both amps and get a good mono amp in the 500 watt range? Then you wouldn't need to separate the two subs in the enclosure, and you would have 8 extra channels not hooked to anything.
