Home Page
Its not browser based. I have Chrome FF IE and Running Opera and Dolphin on my phone all of them have the problem.
I don't know what to do, to fix it. It works fine for me, I just went straight to the homepage and it had me logged in.
I don't understand why it would work for some and not others.
It has to be something in the cookies settings? does it refresh cookies? If i remove them and re log in it works once. But if i leave the home page and come back it goes into the No login mode.
ok just tried this.
Removed Cookies
Re-logged in
Re-Bookmarked
Refreshed
Stayed logged in
Left and close webpage
Came back and was logged out.
Logged in and same problem refreshes back to basic login page.
Removed cookies
Re logged in
Re freshed was fine
Left came back Logged out.
Repeat
I think i found part of the problem.
This cookie once removed fixes the problem and its set to refresh after each session.
[ATTACH]1645[/ATTACH]
[The extension bmp has been deactivated and can no longer be displayed.]
This could also be part of the problem
caraudiocentral.net ? 363cb31274ee369a34ac4a09a13fbbd3&
This was the first link i book marked that worked and when i returned to it during an open session it stayed working. As soon as i closed and re-opened it no longer stayed logged in. The next time i did the procedure to remove all cookies re-log in i got the following URL.
caraudiocentral.net ? edb5c2e933487ed1ad3edaf51d4649eb&
So obviously the URLs for our Home page with log in's don't stay the same. That could also be the problem.
I cant even post the URL because it automatically shortens it for some reason. i dont get it. guess ill have to take a picture and post it.
In the urls posted above i removed a / and =S where the spaces are.
Then change the address your bookmark links to.
Mine is http://www.caraudiocentral.net/ and the home page works just fine.
JeremyC wrote:Then change the address your bookmark links to.
Ok ill try this again.
When using the link you posted i get the url's i posted...
EDIT.
Now i can click your link and it takes me to the correct login page but if i refresh it kicks me out and changes URL to the ones i posted.
Double EDIT Removed all cookies and typed URL in and typed jeremy's URL into the bookmark screen (NOT USING AUTOBOOKMARK) and it works fine.
Thanks Jeremy.
No problem man.
so everything is fixed now?
I think that might be why I never noticed it, I was going directly to http://www.caraudiocentral.net
