im helping a friend install an audiocontrol epicenter and i wanna make sure i get this correct.
the rca's coming from the head unit go into the balanced inputs of the epicenter, then i get a separate pair of rca's, plug them into the output of the epicenter, those same rca's go into the input of the sub amp. is this correct?
http://www.sonicelectronix.com/item_150 ... HITE-.html
epicenter installation help
I would think thats it.
One set in, one set out.
yeah that sounds right to me too. I think the epicenter (as well as other devices of the same type) are pretty straightforward.
Tim
Tim
Tim Strong
Email: [email protected]
X-box Live Gamertag:quad drpr
Tim Strong
