new install
new install
Post by sinister audio »
this is for all the members that arnt platinum. this is my newest install. here are the specs. tell me what you think.
1991 mustang gt 5.0
deck: eclipse 8443
front: Bravox kevlar 5 1/4" comps
rear: Bravox coax 5X7"s
Subs: 2 Bravox UXP 12D4
amp high/mids: Hifonics Eagle 50X4
amp subs: Hifonics BX600
install: pretty clean and simple, vinyl wrapped kicks, box, amp rack. nothing too fancy but should be pretty nice. i should have about 20 hours or less in the complete install.
Sweet job, well executed.
ill have to try laying more vinyl because its not too good or atleast i dont think so, atleast it was my first time doing it.
71buickfreak
Post by 71buickfreak »
theres a cool trick you can use to clean up those cut outs where you have the coners exposed (It looks like they are in the pic, it might not be) you take a different colored vinyl (for accent) and a piece of thin card stock. you lay the good side of the vinyl against the inner edge of the cut out and place the thin strip of cardstock on the inside, staple it in place, then pull back the vinyl and staple it to the back side of the panel. do this all the way around the cut out and you end up with a nice accent trim that looks trick. or you could just use a heat gun and really stretch the vinyl till it clears the corner. gotta be careful so you don't burn and melt the vinyl.
