OHMS question
aaronrchr
Post by aaronrchr »
audiobass10 wrote:lol. Oh well atleast my setups were loud ;)
Past tense, queer boy.
Tim
Post by Tim »
Evanjl wrote:Im hooking up a crunch 1200w amp to an orion 10" 4000w sub (max values). Wondering about ohm loads. My amp is capable of a 2 ohm load and so it the sub. what is the best way to wire it to get some good power without frying my amp. the booklet shows configurations for a 2 ohm load on the sub and a 4 ohm load on the amp. Or a 4ohm to 4 ohm load. or i dont know if it is an option or not but a 2 ohm to 2 ohm load.
also any information of ohms and what they are would be appreciated haha all i know is that my amp makes more rms at 2 ohms compared to 4 ohms
You got some more info on the sub and amp?? first off dont worry about "peak" or "max" rating, they are useless, merely a ploy to make people think they are getting more than they are.
How much power will the amp put out at 4 ohms??
Cause most subs (well built ones anyway) can sound good on about a third of the rms power. So if sub x has a rms of 400 watts you could give it 120 watts and it still sound pretty decent.
Your lower ohm loads will tend to be harder on the amp, the lower the load the more power you get, but it is harder on the amp.
Look at your specs and see what you come up with. And by all means look at the link posted above.
Tim
Tim Strong
Email: [email protected]
X-box Live Gamertag:quad drpr
Post by audiobass10 »
Tim wrote:You got some more info on the sub and amp?? first off
Tim
That's really gunna depend on the sub. There are a lot of sub's that just aren't all that efficient and need the power. If you're going to throw a third of the power on most any sub, you'd better make sure you make up for it in box design.
For instance in my brothers camry, he's got an 18" FI BL fully loaded. With 1200 watts the sub hardly even moves even in a pretty efficent enclosure. Granted it has the extra stiff spiders. Just saying it really depends on your situation with how much power your going to need.
Tim
Post by Tim »
audiobass10 wrote:That's really gunna depend on the sub. There are a lot of sub's that just aren't all that efficient and need the power. If you're going to throw a third of the power on most any sub, you'd better make sure you make up for it in box design.
It is gonna depend on the sub, I agree with that. But the most any sub is what I have a problem with. An 18" FI BL fully loaded is not just any sub. That is a masterpiece, at least in my mind. I have found that I can enjoy a subs performance on a little clean power, better than I can running it at or near its full rms.
And it will depend on the situation how much power you need.
Tim
Tim Strong
Tim wrote:It is gonna depend on the sub, I agree with that. But the most any sub is what I have a problem with. An 18" FI BL fully loaded is not just any sub. That is a masterpiece, at least in my mind. I have found that I can enjoy a subs performance on a little clean power, better than I can running it at or near its full rms.
Tim
Sure you can enjoy it without throwing it it's full power, but to get it's full potential you're going to need to throw some power at it for the most part.
Tim
Post by Tim »
yeah I can dig that.
out of curiosity how much power will that 18 FI take??
Tim
Tim Strong
Tim wrote:yeah I can dig that.
Tim
I'm pretty sure they don't give seperate power ratings for the fully loaded and the regular BL, so i wanna say its 1000 rms. But with 1.2k on it now, it laughs at it. It does a 140 and you can literally hardly even tell its playing lol. My bro's got an American Bass VFL series amp which he plans to switch too which should be feeding it around 2400-2600 wrms, so it should really come to life then.
Tim
Post by Tim »
audiobass10 wrote:I'm pretty sure they don't give seperate power ratings for the fully loaded and the regular BL, so i wanna say its 1000 rms. But with 1.2k on it now, it laughs at it. It does a 140 and you can literally hardly even tell its playing lol. My bro's got an American Bass VFL series amp which he plans to switch too which should be feeding it around 2400-2600 wrms, so it should really come to life then.
Man... I cant imagine having something that handles that kind of power.
LOL
Tim
Tim Strong
Tim wrote:Man... I cant imagine having something that handles that kind of power.
LOL
Tim
hah, yea he got a great deal on it, but had no idea it was gunna need that kind of power. It's in a toyota camry and the enclosure is sealed off from the trunk tuned to 30 or 31 hz, so it gets real low and sounds pretty damn good. He just needs the extra power for it to really shine and also it should help it out in the higher frequencies of the spectrum. Plays chopped and screwed stuff really well right now though. I'm sure we'll get some pics of his setup once it's all completed and cleaned up. Right now you can see the expanded foam and stuff until he gets the beauty panel on, so it's not too pretty to look at.
