how many people think this is stupid?
i dont know if this is the right spot but i will say here and it can be moved if needed, alright if you would have say a 92 firebird that had a 305 and you blew the motor and put a 350 in there and put a carb ontop and have the fuel pump run constantly because it was a ghetto install would you call this stupid or is it just me? there is a guy over on car audio forum that did that and its just blowing my mind how stupid that was or am i the one who is retarded? anyway i think im gonna stay away from that forum for a long time its messing my brain up.
That guy is a frickin tard.
My advice if you want to hang at CAF is to not go into the WOT forum as it warps minds... The people in WOT do whatever they can to mess with you with no regaurd to who you are or what you know. Even if they are wrong and know it they are still right in their eyes...
I run a 140 gallon per hour electric fuel pump from a fuel cell for my 850CFM 4bbl carb to supply enough fuel for the big block with the nitrous enabled, but it's set up right for a carb'ed motor.
That guy with the 355 and the carb has issues. Most of the people on CAF do. especially some of the dumbasses like Feandil and Nutmegs.
I stopped even bothering to read that retarded forum.
with the GV overdrive unit I haave a 3.20:1 final gear ratio in 3rd with OD, so I can get around 15MPG highway.. maybe a bit less.
If I run without the OD unit turned on, and just use the straight 4.11 gears in the Dana D60, it drops considerably. especially if I get into it. I get closer to the 5 to 8 mpg range.
There's always a price for power. That's running 93 octane on the street and 100 octane at the strip if I'm there all day.
