how do you wire your headunit??
cool mr grinch
Post by cool mr grinch »
ok, i know what those are. never actually used them though.
James-aka-Cool Mr Grinch
I solder then use shrink wrap.
Though If I'd did a ton of installs I'd probably find a faster process.
Tim
Post by Tim »
I like the crimp caps because they are faster. But I also solder them from time to time though. Never tried the butt connectors, and probably wont.
Tim Strong
Email: [email protected]
X-box Live Gamertag:quad drpr
crimp caps and tape
i was at the dollar store the other day and they had so Dora the explorer bandaids on sale so i go those to secure my connections....adds a little bling and save me a nickel
Tim
Post by Tim »
smoker wrote:i was at the dollar store the other day and they had so Dora the explorer bandaids on sale so i go those to secure my connections....adds a little bling and save me a nickel
And if you get cut while installing you have the bandaid already there.... :happy055:
Tim
Tim Strong
brisgreat1
Post by brisgreat1 »
lol i just twist and tape em up, but i would like to get 'into' caps and possibly soldering. just a little scared of geting ahead of myself :P
tin the wires, solder them, then heat-shrink tubing over the connections using a wiring harness for plug-n-play action goodness.
...sans the harness in my car, as it was pre-plug era.
falkenbd
Post by falkenbd »
I solder, except the remote wire, since it doesn't go through the harness. I use some sort of disconnect for that. Like an Anderson power pole.
It doesn't take very long, all 4 wires took me about 10 minutes...
Post by CaptainPioneer »
I crimp cap..... Butt end only when needed to... Used to solder but have burned the crap out of my hands so many times... I wish I had a head shrink Gun thing. Or a mini Butane torch... I have the big guy for soldering copper pipes but Im sure thats a bit much...
