Wire w/ White Line + or -?
NorthQuad
Post by NorthQuad »
I can't frickin' figure it out. I'm an idiot.
On the Alpine Pro tweeters, is the wire with the white line positive or negative?
Is the white line usually positive? That's what I'm thinking.
Thanks.
falkenbd
Post by falkenbd »
I'd guess negative. Is polarity marked on the tweeter?
NorthQuad
Post by NorthQuad »
falkenbd wrote:I'd guess negative. Is polarity marked on the tweeter?
No, nothing is marked. I've checked the Alpine site and also the manual it came with... but no action'.
I found a sketch of other Alpine tweeters (online) that had the striped wire as negative. So, I hope they follow that route with every model. I'll go with stripe as negative.
Thanks man.
falkenbd
Post by falkenbd »
I've bought quite a few speakers that came with speaker wire. normally the striped is neg.
You're welcome
Run a phase check on it after its done.
Post by CaptainPioneer »
yea on the alpines the anything with the stripe is usually the negative.
How much for the tweets if thats ok to ask?
I would consider purchasing some alpine pro's for my truck since my highs have not been coming through the way I want with just comps.
NorthQuad
Post by NorthQuad »
I purchased the SPX-17PRO set for $200 or so less then retail at a local place. I'll find out today if that was too much.
I found a Digital Designs dealer in town and probably would have tried a set of those instead had I found him sooner. I dunno, guess I'll know soon enough.
NorthQuad
Post by NorthQuad »
Well, must have been negative because they sound nice and crispy.
Tim
Post by Tim »
Generally speaking, a stripe on a wire is indicative of negative. Not always the case, though. I have seen the stripe be positive.
Tim
Tim Strong
Email: [email protected]
X-box Live Gamertag:quad drpr
Well if you were to look at my system it would be the complete opposite. I use the line wire as positive all the time.
