Have a cool ride? Then show it off on our website ! All vehicles welcome!
tommy.l
Posts: 27 Joined: Mon Dec 22, 2008 2:20 pm
Post
by tommy.l » Sat Mar 14, 2009 4:08 pm
when i turn my musinn up real loud it always cuts in and out. i just got a power cap but it isnt stopping it
Posts: 4919 Joined: Thu Oct 07, 2004 4:00 am
Post
by MobileAudio219 » Sat Mar 14, 2009 4:13 pm
tommy.l wrote: when i turn my musinn up real loud it always cuts in and out. i just got a power cap but it isnt stopping it
Whats a musinn?
I'd say your probably clipping the amp pretty bad. Also check your ground wire.
tommy.l
Post
by tommy.l » Sat Mar 14, 2009 4:18 pm
i meant music... the ground is well connected to the chassis.
Post
by MobileAudio219 » Sat Mar 14, 2009 4:22 pm
tommy.l wrote: i meant music... the ground is well connected to the chassis.
Also check that the power wire isnt coming lose at the battery, fuse holder or amp.
How are you gains set? Are you running multiple amps?
falkenbd
Posts: 932 Joined: Tue Nov 20, 2007 8:39 pm
Post
by falkenbd » Sat Mar 14, 2009 4:31 pm
could be overheating the amp, its probably going into thermal protect. or another kind of protect.
swimmerdude
Posts: 1131 Joined: Wed Sep 28, 2005 5:08 pm
Post
by swimmerdude » Sat Mar 14, 2009 4:32 pm
clipping would be my guess?? let us know some more info on what you are running and exactly what is happening.
tommy.l
Post
by tommy.l » Sat Mar 14, 2009 4:36 pm
what is clipping? i am not running multiple amps. the gain is about half way
swimmerdude
Post
by swimmerdude » Sat Mar 14, 2009 4:39 pm
clipping would mean distortion. or it could also be that the amp is shutting off and turning back on due to lack of voltage. that lack of voltage could be caused by many things like a weak charging system, poor ground.... even if it is grounded to the frame, the tiniest amount of paint making insufficient contact can lead to a bad ground.
falkenbd
Post
by falkenbd » Sat Mar 14, 2009 4:43 pm
clipping is when the amplifier "clips" or distorts the signal because you turned the gain too high.
