Autotek refurb problems
cool mr grinch
cool mr grinch
well i found the problem, after doing the new paneling and sealing of my drivers door i had to reroute my speaker wiring, i had rerouted them to low and when i installed the panel one of the screws had pierced the wire coating and when the car was running the wires would vibrate and rub against the screw, so i rerouted them further up repaired the wires and everything works great now.
Wiring seems to cause a lot of problems over the years.
Ive seen power wires run thru drilled holes in firewalls. Over time it will slice thru the shielding and BAM... lol
Screws thru wires... Common.
cool mr grinch
Try swapping the RCAs also. Doesnt hurt to try and make sure its the true problem.
cool mr grinch
