just hooked up at RF punch HE2 :-D
Dragon_fire
Post by Dragon_fire »
If the sub is a dual voice coil, each @ 4 ohms, then you could wire it for a 2 ohm load or a 8ohm load. make sure your amp can run @ 2 ohms. And make sure your not going crazy with the gain. Generally dual 4 ohms would be used in a multiple sub configuration. ie , i have 2 subs which are dual 4 ohm voice coils. I have each setup to be a 2ohm driver, then I wired them in a series to get a 4 ohm load on my amp.
MrSo0h0o
Post by MrSo0h0o »
i know the amp is 2ohm stable, but im not sure if it is 2ohm stable while bridged. i suppose i could wire it at 8ohm instead so i dont put too much pressure on the amp? the gain is no more than a 1/3 of the way up, i made sure of that.
Dragon_fire
im not %100 certain, but usually when you bridge channels on an amp they are not low ohm stable.
MrSo0h0o
Post by MrSo0h0o »
what exactly is happening when the sound goes out? the amp goes into thermal protection? does that mean it began to clip?
taylor17
Post by taylor17 »
Yup, usually its only 4 ohm stable. If you run it at 8 ohms, it will be fine, you just won't get near the power.
BTW, I have the RF HX2's, and I believe the HE2's are 400 rms.
MrSo0h0o
Post by MrSo0h0o »
i got the 10in, the max was 600 so i figure rms is ~300. about what power would be going to the sub at 8ohm wiring?
Dragon_fire
Thermal protection is just that. Protection from heat. Usually if the amp is going into thermal its clipping before it does. If your putting out 150 bridged as is, then at 8 ohms your looking at probably less then 100...way less, maybe less then 50. What amp ? Exact model please.
MrSo0h0o
Post by MrSo0h0o »
its an eclipse EA3422 4 ch amp(has 4/3/2 ch modes, currently running it in 3 ch mode:Front ch regular, rear ch mono bridged)
i suppose if i keep everything low and make sure the amp doesnt clip, is it ok to keep running it like this?
Dragon_fire
IMHO, maybe you could sell the sub and buy a lower power one. maybe a JL w0, or kick comp. something that takes about 100 watts rms. Try to match the speakers to the amps, underpowering a speaker is just as bad as too much, if not worse. Underpowering creates distortion which = not good for speakers.
For now, it would be better if you set the rear channels (I'm assuming you are just using the rear for the amp to be 3 channel) in mono, but hook one voice coil to the R and the other to the L. The rear channels MUST be in mono! That way you will get the most power you can to the sub while not killing anything in the process. Be glad you have an amp that is decent enough to let you know you are pushing it too hard :)
