Ok so if its all around the car that increases the path length.spkrman wrote:If the path of least resistance is all around the car, that increases path length at the same time.
I actually performed a sort of a "test" where I used my old frame ground with upgraded ground up front with just my rear battery to start the car. It was *much* harder to start than with just the 2/0ga wire up front for ground.
The best way was with both connected :)
But adding a wire AND using the car does not?
That should show you your logic on this issue is flawed...
Path length has nothing to do with it. It will flow from one contact point to the next by the route of less resistance.
It has been long known the best areas for grounds are on or by the subframes as they will conduct more electric. Also because of design they are superior for grounding spots.
