hey fellas!!! i got a ?
can you take two mono amps and wire each one to the voice coil?
will it play with no problem? just something to pick yah minds....
I don't see a problem with that as long as you don't put too much power to the sub, but these guys here are the experts. When I bought my Memphis MOJO, I was given some similar info. The 15" 15-MOJO15Q1 will take a 1000 watt mono amp on each one of 4 (1 ohm) voice coils.
I've got the 12" dual 2 ohm and decided that parallel connection was enough for me, besides, I only have room for the one amp :)
nah i don`t it was a ? i thought of asking on here.
Let`s use this example
you have 2 900 rms mono amps and you decide to get one high price sub
to replace the ones you have you can't afford but one $400.00 sub
that handle 2000 rms of power so working with what you have instead
of trying to sell them and start over.
ive done it its really not that bad just make sure you gain match. and not just with a dmm to check voltage. your current could be off as your coils will have slightly diffrent impedances. which changes your Voltage and current. which is y im a firm believe in using both dmm and clamp to set gains.
