Focal sub installed
Focal sub installed
Well I finally built a box and installed my Focal 33v1. Will it get louder as it gets broken in? I am kinda disappointed in it right now, I thought it would be louder. I have only had used subs before so I'm not sure, but I thought I read that they would get louder after break in. If its as loud as it gets now I think I will get a new sub and amp.
- Attachments
- 8.jpg (385.47 KiB) Viewed 863 times
- 7.jpg (333.07 KiB) Viewed 863 times
I'm on board with these guys... chances are it's the box and not the sub.
The box is 1.79 cu. ft. and tuned to 32.65 Hz. The sub is a single 4 ohm 400 watt RMS and the amp is a ppi PC2400.2. The amp is bridged, left positive right negative. It should be getting at least 400 watts. I have read that these amps are underrated so it may be getting more.
I think I tuned it to low.
Does it get louder after break in? Because it does seem better know. Maybe the problem is my old sub, the Focal sounds way tighter. Maybe I just need some time to get used to it. Right now its in the wifes car, but when I get back from Chicago later this week I'll move it to my car.
Your port area is just to small IMO. I dont have specs handy but I could look it over for you when I get some free time?
