Power Wiring for '99 saturn sc1
Im trying to get a power wire from the battery to the amp in the trunk of my '99 saturn sc1 and i can not seem to find a way through the firewall seperating the engine compartment from the rest of the car. Anyone have any ideas?
The car is a manual, so going through the hole where the clutch cable goes is a no-go : (
Yup... Drill is the only way to go on those... Although there is plenty of space on the lower firewall that you can drill through without coming near anything... still be careful thoughsolacedagony wrote: Otherwise, you're probably going to have to drill a hole and grommet it.
loudwagon15s
Actually I hate to break it to you... but that's really not a crafty trick at all... It's more the cheap and easy way of doing it and doesn't make for a very clean install... Also I have seen more than my share of peoples vehicles that do it that way that end up pinching the power wire in the door and either start having power problems or get start getting lil electrical pokes from their vehicle.
I'm not saying this to sound mean, just to be informative... Do it right the first time by drilling and save yourself some headaches down the road :)
Oh and the best place to drill is upper left drivers side under the dash... If you get under the car you'll see there is a ton of space right there on the firewall... Oh and one of the reasons you can't find an existing spot for a grommet to feed through is because Saturn put most of the wires through the fender and then back into the car.
Sorry...
But if you wanna get really advanced without drilling... You can always take the front drivers side fender off and then run the wire through the body and back into the cab.
