car problem
Could the clutch be completely gone now?
ryno, first welcome to the board...ryno_26 wrote:ok i have a kenwood kdc-mp7028 and dont have the users manual to it...could ne one till me how to change the time on it???
2nd) For future reference please only list your problem in someone elses thread if it is of the same nature
3rd) Go here to for the PDF file of your manual that you can print out: http://inform2.kenwoodusa.com/manuals/KDCX889.pdf
:happy055:
colemanyoungerinalaska
Could one of the starter wires be loose or could be the pinion jammed (try hitting it with a hammer... not hard just a couple good smacks to see if it breaks loose and then starts).
Could also be the solenoid went bad.
distributor? ignition control module? and also, you could go ahead and replace the fuel filter, dunno about on yours, but for my truck they are only like $10..
here is something i found for my trucks transmission, its a common problem, although may not even have anything in common with a Honda, i dunno.:
1-2 Shift shudder at WOT; delayed or abnormal 1-2 shift; There's a problem ONLY on the 1-2 shift: 1-2 accumulator piston cracked or stuck cocked in the bore. Check the yellow spring inside the accum housing for breakage. Also, if the accumulator housing walls are scored, the housing must be replaced. Easy fix in the pan.
Definately start checkin sensors... especially since you said that you were off roading with it the other day... you may have loosened something up enough to have finally broke loose or become disconnected.
