Kinetic fans
Kinetic fans
For all of you who wondered y i'm not a big fan of kinetic and y i usually recommend stinger ODYSSEY or tsunami
Kinetic is being sued for false advertising and misleading customers by powermaster. when i find the damn link ill post it
haha...
My exes other kids dad help start that business. Bunch of computer nerds.
Tim
Post by Tim »
Well, that certainly is good info to know, I dind't know you didn't like them though Bill, but I'm glad you are keeping us in the know.
Tim
cheapaudio
Post by cheapaudio »
yea i just read on ssa about the kinetik batts. something bout they dont like voltages above 14.3 or something... they loose their ability to hold charges after awhile.
breakjunki
Post by breakjunki »
a little off topic, but the DEKA intimidator seem like good batts and I get them cheap local...
Deka is wayyy up there on my list right with anything enersys makes.
Tim
Post by Tim »
Yeah me too I like DEKA batteries.
Tim
sayhuh
Post by sayhuh »
intresting but PM has specs all over the place as well and the battery issue they are going after isnt even car audio related. it is racing related on a battery i dont even know is out yet.
these are authorized dealers
http://store.summitracing.com/partdetai ... t=pwm-1000
Brand: Powermaster
Product Line: Powermaster AGM 16 Volt Batteries
Part Type: Batteries, Automotive
Part Number: PWM-1000
Battery Usage: Deep cycle/Starting
Volts: 16 V
Battery Terminals: Top
Battery Type: AGM
Cranking Amps at 32 Degrees F: 650 amps
Reserve Capacity: 85 minutes
the instruction book attached says 600ca at 0 degrees C which is 32 degrees F
http://static.summitracing.com/global/i ... m-1000.pdf
another authorized dealer
http://www.batteryservice.com/products_ ... r=16V-1000
Model Number: 16V-1000
Dimensions: 10.31 x 6.6 x 8.125
Post Type: 3/8" Insert
Description: 16 Volt Racing Battery - AGM
CCA @0°F: 747
CA @32°F:
926
Reserve Capacity:
84
so is it 600 CA? 650 CA? or 926 CA? 32 degrees F = 0 degrees C doesnt it?
Powermaster now only has MaxAmps and AH as specs on their websites..... HMMM wonder why? you go looking at those specs too they will be different from site to site.
I have owned a stinger SP1000 battery for almost 2 years and it is the only battery i owned that needed a charger to keep working. oddly enough the old wet cell didnt need a charger (just dimmed slightly) and the new wet cell i replaced the stinger with didnt need a charger either and going off specs they were smaller batteries. have had my kinetik for many years and it hasnt seen a charger yet and works great.
bring up the stinger test? they gave a max amps rating a CA rating and tested to it. also like to know since when is a CA rating even needed to run car audio? it is a test that runs down a 12v battery to 7.2v at 30 seconds with no care in the world at staying at or above 10v. it really isnt even needed any more to start a modern car. it is an old engine starting spec that companies use because they are rebadging a engine starting battery for car audio. LOL
The only stinger battery i like is the re-badged enersys 2150. ive tested a pm kinetic and a enersys 2150 and the kinetic was the worst by far. there is far more on this subject i wont get into. if you like kinetic buy them. if you like whatever you like buy it.
sayhuh
Post by sayhuh »
Bwcad1 wrote:The only stinger battery i like is the re-badged enersys 2150. ive tested a pm kinetic and a enersys 2150 and the kinetic was the worst by far. there is far more on this subject i wont get into. if you like kinetic buy them. if you like whatever you like buy it.
I do but i also know that kinetik has won and still wins so it mustn't be total junk eh? The guys who use it must know what they are doing and still use them. Odyssey 2150 came out when 1999 and has been used in comps since then?
I know a guy that runs a 4kwatt amp. He runs 2 stinger or odyssey 2150's (not sure which like it matters) even though they are good for "5000" watts each he has to run 2 or it makes the amp go up in smoke at least it did off 1. It's not built for all out comps and it posted scores that a kinetik user in a lower single battery class could beat. I also know a shop that dropped stinger batteries because they failed and switched to westco (the place I bought mine). If you are doing 148's in a class where your buddies are doing 153+ you need A LOT more than batteries to begin with (that isnt a slam against anyone either its just a fact). Not saying stinger or any these are bad or kinetik is best. Just stateing that kinetik works and works well for what they say it does and from what i have seen and know they dont fail much especially if they are used the way kinetik states for daily use. Every brand no matter how good it is will have people who like it or don't. :happy055:
