Amp Cover/heat sink
dmeyer07
Amp Cover/heat sink
Post by dmeyer07 »
Okay i have a question about 2 amps. I want to have 2 of my amps in an amp rack both facing the same way,etc. I want the power wires/speaker wires/etc all to be in the middle of the amp rack. This works out for both my amps because the Rca inputs are on one side and all of the rest is on the other. So i figured if i took bothe my amps and faced the Rca's to the outside of the amp rack then all of the power wires/rca's,etc could be in the middle. Well that works out fine for my sub amp, but for the speaker amp in order for me to do that i'd have to completely flip the amp around, and the writting would be facing the opposite way. Is there anyway i can just flip the cover around or something to take care of that problem?
Thanks for the help....
Depends on the amp. what amp is it? Also, you don't want your power and speaker wires touching your RCA cables.
dmeyer07
Post by dmeyer07 »
http://www.crutchfield.com/S-l7sHDzdwBqz/cgi-bin/ProdView.asp?g=120&id=morephotos&pi=2&i=489AP1040&display=XL#Tab
Yea i know not a great amp but for free what the hell.
Yes i know that Rca's and power will be away from each other, they are run on opp. sides of the car, and i want them on opp sides of the amp rack away from the power wire....
Well flip the amp over, unscrew it and open it up. Generally the internals are all connected to the top of the amplifier, not the bottom, making it impossible to flip anything around. So more then likely, no.
dmeyer07
Post by dmeyer07 »
Damn that sux, thats gonna look kinda silly having the amps face two differnt ways.
But i'd rather have that then have my rcas right next to my power and speaker wires.
Any ideas?
Take all of the labeling off the amps.
dmeyer07
Post by dmeyer07 »
That just stickers?
I don't want a blank amp either though, maybe i could just take em off and put em on the other side.
:confused
I doubt you can take them off anf reuse them lol. Sometimes i think blank amps look good.
dmeyer07
Post by dmeyer07 »
Hmm i'll do a lil photoshop and see what they look like blank
What about placing the amps in a different configuration? Such as [] [] instead of - - and have the cables on the same sides.
