sub air pushing 6x9 cones?
Im wondering if this is a big problem/concern.
I was playing my sub the other day and i went to the backseats and looked at the 6x9's (they werent hooked up but were in placE) and the air from the sub was moving the cone up and down (not drastically but you could tell when the sub was hitting)
i know its not good to push cones in and out manually, so what can I do to fix this (if it is a problem)? I'd imagine it would be even worse when the 6x9 was getting power because it might be trying to move one way while the sub another..
anyways just wondering if im gonna need to build some sort of box int he turnk that bolts to the rear deck for them or something?
thanks guys
thanks guys
Mercedesbends69
71buickfreak
Yea, it shouldn't be a problem as long as the pressure from the subs is exurting an equal force on the whole cone (which it should be). When people press down on cones with their hands, they have a tendency to push it sideways rather than straight which is where the actual damage takes place.
Mithrandir
PPIFLATCONE
Take them out.
You want to port the trunk to the cabin anyhow. You actually want it so there is no resistance of air movement between the both (volume dicated by subs).
This will help couple the air in the two chambers better.
