constant squeeling noise
Scarrell
Post by Scarrell »
ok, for like the past week, my trucks passenger side(i think its the front passenger wheel or whatever) has been making this god awful squeeling noise.. and it only stops when i apply the brakes.. i dont know what it is.. maybe i need new brakes, but does anyone have any ideas? its really F#cking annoying.. :banghead
scotts1000rr
Post by scotts1000rr »
probably your brakes
Did you pull off your wheel and look at your breaks to see the big hole that's now in your rotors? :)
Post by CaptainPioneer »
it could be his breaks but it also could be something on the inside of the of the rotor.
COR UNUM VIA UNA - Jay Chmura
In any case, you should pull the wheel off and take a look. I dunno if it can cause that kind of noise, but check wheel bearings as well.
double
captaincheesey
Post by captaincheesey »
My step-mom had a similar problem where her brakes would squeel only when she accelerated. Turns out they were put on upside down, but her brakes did need to be checked anyways.
most likely the brakes the wheel bearing doesn't really squeal makes a howling noise when the wheel is turned or just howls constantly.
yea thats what my truck has Bill... cept its coming from the rear... :(
u have a dodge right? it's really a pretty easy fix.
