System stops working
Evanjl
Post by Evanjl »
When i get in my car and start it my subs are not working but then after i drive around and come home as soon as i pull in the garage and stop they start working it has happened 3 times now or i wouldnt have thought anytihng was wrong
Darthness
Post by Darthness »
my guess is loose wire(s)
- Keith
captaincheesey
Post by captaincheesey »
The subs do not like you, lol.
Evanjl
Post by Evanjl »
yea i went and jiggled the wires and no go soo not sure what i am goign to do yet
Scarrell
Post by Scarrell »
yeah more than likely lose wires, take the subs out and check, check the rca's on the back of the hu/amp, remote wire...etc...etc..
scotts1000rr
Post by scotts1000rr »
i had my power wire come loose at the fuse holder not too long ago on the way to columbus with nothing to tighten it up with. 2 hours of the subs going on and off every ten minutes it about drove me nuts i finally pulled the wire the rest of the way out and drove subless. i think that was worse
Evanjl
Post by Evanjl »
well i messes around with it for awhile and the conclusion is that my subs only work when i have my park brake pulled up...whish would make sense seeing how i have all my wirers running right around my hand brake through the center of the car so im guessing i am pinching of grounding a wire out some how..which sucks becasue i have to take a lot apart to get under my center consel
Yup sounds like that's your problem... better get that fixed asap before you start getting lil or big shocks from your car.
BryanX33
Post by BryanX33 »
scotts1000rr wrote:i had my power wire come loose at the fuse holder not too long ago on the way to columbus with nothing to tighten it up with. 2 hours of the subs going on and off every ten minutes it about drove me nuts i finally pulled the wire the rest of the way out and drove subless. i think that was worse
I've been driving subless AND radio-less for 2 and 1/2 months. Feel my pain lol
UndercoverPunk
Post by UndercoverPunk »
cargodz wrote:Yup sounds like that's your problem... better get that fixed asap before you start getting lil or big shocks from your car.
Not going to happen.
