I am looking at buying an amp to power my 2 12'' infinity perfect 12.1
* Size: 12 inch
* Rec. Sealed Box Dims: 1.00 - 1.00 cu. ft.
* Rec. Ported Box Dims: 1.75 - 1.75 cu. ft.
* Free Air Usage: not recommended
* Sensitivity: 96 dB
* Frequency Response: 18-150 Hz
* Recommended RMS Power: 350W
* Peak Power Handling: 1400W
* Impedance: 4 ohms subwoofer wiring options
Would like to know what you guys think would be best.. Trying to keep it around $400 Canadian.
Thanks alot
Buying an amp
- swimmerdude
You will want an amp in the 600-800rms @2ohms. Check this brand ratings list to see what to look at and what to avoid.... http://www.caraudiocentral.net/forums/s ... d.php?t=32
Although on a $400 canadian budget you may want to look into 400-500wrms @ 2ohms for some slightly better equipment, check out the thread Mike (swimmerdude) mentioned.
- swimmerdude
loudwagon15s
