Amp/speaker combo
marc
Amp/speaker combo
Post by marc »
Trying to get my system up and running.
I plan on using as mch of this equipment as possible, but am struggling with the optimal matches. The one in bold is what I plan on using. But I still have an unused Zapco amp I would like to use. Ideally, I would like to use the 3 zapcos, The JL, and the Memphis, but I cant seem to get the speakers matched to them. Any ideas?
Thanks Marc
Any ideas?
AMP Specs Location Brand Ohms Size RMS
Amp 1
25 x 2 @ 4 ohms rear fill Triaxle 4 6x9 25 wrms
Amp 2
Amp 3
85 x 2 @ 4 ohms door Pioneer 4 6x9 80 wrms
Bridged 170 x 1 @ 8 ohms
JL E2150
45 x 2 @ 4 ohms
75 x 2 @ 2 ohms Dash Beyma 4 4 35
Bridged Mono
90 x 1 @ 8 ohms
150 x 1 @ 4 ohms
Memphis PR 200.2
100 x 2 @ 4ohms
140 x 2 @ 2 ohms Mid Polk DB 4 6x9 100 wrms
Bridged Mono
280 x 1 @ 4 ohms
Zapco AG 200
50 x 2 @ 4 ohms
100 x 2 @ 2 ohms Front Beyma 4 5.5 Comps 45 wrms
Bridged Mono
100 x 1 @ 8 ohms
190 x 1 @ 4 ohms Front Beyma 4 5.5 Comps 45 wrms
Zapco Z100C2
25 x 2 @ 4 ohms
50 x 2 @ 2 ohms
100 x 2 @ 1 ohm Mid Polk DB 4 6x9 100 wrms
Bridged Mono
100 x 1 @ 4 ohms
200 x 1 @ 2 ohms
Zapco Z100C2
25 x 2 @ 4 ohms
50 x 2 @ 2 ohms
100 x 2 @ 1 ohm
Bridged Mono
100 x 1 @ 4 ohms
200 x 1 @ 2 ohms
Is it just me... or is that just an awful lot of 6x9"s in that car...
I can't help but ask if those were typo's on your part, because if not the vehicle will definately not be geared toward sq (odd shaped speakers are not known for premium sound quality)... And did I catch the amount right... 4 of each?
marc
Post by marc »
Total of 8 speaker amps plus sub amp
10 6x9s- 2 in Doors, 2 in rear, 6 in mid area
2 sets of 5 1/2 components, -Beyma for overhead.
1 set of Beyma 3.5 for dash.
Its in a van
Holy 6x9 hell!
When you start getting that much area, with that many speakers you need to concentrate on your imaging as well as speaker placement. Otherwise you may wind up with something that sounds awful and full of cancellation and distraction.
what the hell you going to do with that many 6X9s? that would be to many even for a bus.
Generally, the KISS approach is the best. And your setup is far from KISS. You'd have better results with a single 2-way up front and a single sub for low end and call it a day. The chance that you're going to have similar results with 10 6x9s and 3 sets of components is about the chance of an ice cube lasting in hell.
