A buddy of mine is ..Kicker strong o_O ...
Anyways trying to helpem with a box a lil bit because he's an ignorant idiot and has gotten lucky in the past with boxes and therefore he thinks this 10 ported box he has will be perfect for ANY tens...
Anyways where the heck can I get the specs for the CVX lineup?
Kicker's are so crappy they don't even list them anywhere!!
Specs on Kickers crap
Kicker is more or less just interested in sales.. he can use that 10" ported box on alot of applications, as long as its in the general area the sub calls for.. it isnt "bad" to put a sub in just about any box, you just have to keep in mind if its too big or too small, it will effect the performance of the subwoofer, thus either sound good or like horse balls.. also it can change the tuning of the box:
here is a little bit of what ive found:
# Peak Power Handling 1200 watts
# RMS Power Handling 600 watts
# Woofer Surround Santoprene rubber
# Woofer Composition N/A
# Sealed Box Volume 0.8 - 3.0 cu. ft.
# Ported Box Volume 1.25 - 1.75 cu. ft.
# Sensitivity 87.2 dB
# Frequency Response 24 Hz - 500 Hz
# Xmax (millimeters) N/A
# Top Mount Depth 5-15/16"
# Cutout Diameter N/A
http://www.sonicelectronix.com/item_6511.html
- swimmerdude
http://www.kicker.com/06/tech-support/m ... %20WEB.pdf
That is the Product Manual for the CVX's.... has a few T/S parameters and a few box dimensions. You might have it already, but i dont know.
Also, if you go to http://www.kicker.com and then click support, technical support, and then T/S Parameters if you want to get the full list of them.
ZeroAccess
